Visual Logic: set operation time and distribution
Postby Simul8or » Thu Sep 21, 2017 8:46 am
I would like to set the operation time in an activity with a If..Then... Function.
However the "Set Activity.Operation Time = 0.1" also sets a fixed distribution. Unfortunately I can't find a way to have it set respectively keep the distribution to exponential...
By setting the operation time with a label, I don't see a possibility to set the label value depending on a queues length...
Does anyone have an idea?
Re: Visual Logic: set operation time and distribution
Postby jholtman » Sat Sep 30, 2017 5:55 am
create a distribution which will have a name and then that name in your assignment
Jim Holtman
Data Munger Guru
jholtman (at) gmail (dot) com
What is the problem you are trying to solve?
Tell me what you want to do, not how you want to do it.
