Simulation Assistant Wizard needs to be turned-off
Postby navonil » Mon Apr 27, 2009 6:48 pm
Hello
I am using "Simul8 Professional Edition version 15.0 Build 1617". I am accessing Simul8 through COM. From time to time the Simulation Assistant offers advice. I need to turn-off this feature because an user input is required (cancel or ignore) to continue the simulation run and this affecting my performance results.
I have tried to switch-off this feature in the following way:
Tools > Wizards > Simul8 Assistant
Then I have ticked the check box "No support".
But this still then the Simulation Assistant keeps reappearing.
I have looked at the Simul8 Help Feature and it advices the following:
"If you do not want the assistant to watch your simulation you can switch it off (choose Wizards / SIMUL8 Assistant in the main menu and check the Hide All Advice check box)."
HOWEVER, I CANNOT FIND ANY "HIDE ALL ADVICE" CHECK BOX.
I would greatly appreciate any help that you can offer.
Kind regards
Navonil
SISCM
Brunel University
Uxbridge
