Conveyor - do work without removing from conveyor
Postby Marcus » Fri May 03, 2013 1:58 pm
How can I change a label in a WI after performing the work in the conveyor with the option "do work without removing from conveyor" checked?
The work need to be done in the conveyor and with this option the WC don't take the WI to do the job inside of it, so the Action to change the label value dosen't work. If I use a VL to change the Label value in a area of the conveyor I can accidently change the value of some WI that I shouldn't.
