MILK RUN - paths + Work entry points issues
Postby jenda-zelenka » Wed Oct 15, 2014 12:28 pm
Hello,
i am trying to make model of milk run.
For example:
4 Loaders - each loader has 1 work center and 1 Work entry point
4 paths in circle with 1 vehicle
First issue:
I need to each Work entry point make 4 different work item so I use Label actions with Rounded uniform from 1 to 4. But in this case Work entry point make: 25% label 1, 25% label 2, 25% label 3, 25% label 4.
But i need to be more specific for example: label 1 -10%, label 2 - 40%, label 3 - 20%, label 4 - 30%. How can I get this result?
Second issue:
For vehicle I set standard route - loader1 to loader 2 to loader 3 to loader 4. So vehicle make circle route.
But I need that vehicle make 2 circle:
1. loader1 to loader 2 to loader 3
2. loader1 to loader 2 to loader 3 to loader 4 but just every n-th circle.
This mean that vehicle should make 1.circle and 2.circle every n-th circle.
Thank you for your response.
