End results segregated by label for multiple runs
Postby Liz92 » Wed Feb 18, 2015 4:22 pm
Hello!
I would have the following question: My results at the end point are segregated by a label, which attaches a number to each work item (as generated by a label-based distribution at the start).
I can however see and export to Excel only the results for the most recent trial/ run (when I click on the end point).
How can I create a variable that summarises all numbers that are attached to the items (the sum of all numbers represents total factory output) and that gives confidence intervals over multiple trials/ runs?
Many thanks for your help!
