Is it possible to retrieve the Job Matrix Timing?
Postby jmerschat » Wed Jul 01, 2015 10:04 pm
Is it possible to retrieve and assign the Job Matrix Timing to a subsequent activity following the routing. I have a very complex routing for an assembly operation so I am using the Job Matrix to route the Work Item to an Activity with zero timing then I will do some batching or collecting in a subsequent function and then assign the required cycle time to the Activity for this particular entity type and activity type. I need to be able to reference the timing from the Job Matrix, but do not see any way to capture it. It is not as simple as making a separate look-up matrix as the Work Items route back through the same Activities with different timings (hence the Job Matrix). There are also some replication issues driving this. I would like to have replicates driven by the Resources, but that locks out all of the batching and collection functionality at the Activity.
Best Regards,
Jason Merschat
Advanced Process Optimization, Inc.
