Need help to build visual logic based on label value
Postby Kumar » Thu Jan 05, 2017 7:01 am
I am new to Simul8, I am trying to build logic for work item exit based on label matching. Consider this example.
I have Start point, Queue 1, Activity 1, Activity 2 and End Point.
Work item A1,A2,A3,A4,A5 labeled attached as 1,2,3,4,5 are entering in Queue 1 and Activity 1, but now I want after Activity 1 using label sequence as 3,4,1,2,5 work items should enter in Activity 2 in as A3,A4,A1,A2,A5 respectively.
Best Wishes,
Kumar
Re: Need help to build visual logic based on label value
Postby jholtman » Sun Feb 19, 2017 11:23 pm
It is unclear what you want. Do you want to change the label after it leaves Activity 1? Do you want to change the priority of the items as they might be waiting in a queue for Activity 2 so that they are processed in a specific order? Do you want to wait until all five of the items are processed in Activity 1 and then change the order of processing for Activity 2?
So try to clarify what you are trying to do.
Jim Holtman
Data Munger Guru
jholtman (at) gmail (dot) com
What is the problem you are trying to solve?
Tell me what you want to do, not how you want to do it.
