Pause Activity 2 while Activity 1 is working
Postby RHDS » Tue May 02, 2017 6:39 pm
Hello, first time using the program. Looking for a way to pause Activity 2 (processing) while Activity 1 is working and vice-versa, so basically let only single Activity work at a time.
Basically, I have 2 item types (healthy goods, damaged goods), only 1 worker and 2 work tables. Worker can simultaneously process either the healthy goods or damaged goods, at one table at a time.
Screenshot: http://i.imgur.com/LjtsSX6.png
Thank you!
Re: Pause Activity 2 while Activity 1 is working
Postby OliverPX » Thu May 18, 2017 3:31 pm
You can put both of the activities in a group, and then limit the group contents to 1. This will make sure only of them can work at any time.
You can read more on this here: https://blog.simul8.com/fridays-tip-cre ... ork-items/
