Distribution for normal and peak times of a day
Postby Billatx » Wed May 17, 2017 1:17 pm
Hello!
I need a distribution in which at the start of the day, from 10:00 to 16.00 the distribution is expo(20) and then from 16.00 to 20.00 the distribution is expo(9)
How should i make it happen?
Re: Distribution for normal and peak times of a day
Postby OliverPX » Thu May 18, 2017 3:22 pm
Hi, have you tried using a Time Dependent Distribution?
You can create two distributions that hold your Exponential parameters, and then create a Time Dependent one to state which distribution is used at which time.
You can read more on this here: https://blog.simul8.com/fridays-tip-usi ... tribution/
