More than one Work Item processed in the Activity
Postby msb1g15 » Wed May 17, 2017 6:41 pm
I have attempted to process more than one work item on an activity by using more resources however the simulation only uses one resource for the activity although more than one are available.
Could someone help me out?
Re: More than one Work Item processed in the Activity
Postby OliverPX » Thu May 18, 2017 3:23 pm
You can use the "Replicate" functionality of an activity that will allow it to process multiple items simultaneously. Select the activity, then navigate to the "Additional" tab of the ribbon, and you will see the value for Replication. You can make this a very large value (ie, 999) if you are using resources, as it will always be constrained by the max number of resources available.
