Pull Items at a certain rate
Postby Simul8or » Thu May 18, 2017 1:11 pm
Hello,
I would like my activity to pull items at a certain time rate from a Queue. Additionally the activity should be able to work on multiple items at the same time.
e.g. Paintshop: Pull one Item every 5 minutes that then stays in the Paintshop for 1 hour. Thus the Paint Shop contains 12 items.
Thank you very much!
Re: Pull Items at a certain rate
Postby OliverPX » Thu May 18, 2017 3:37 pm
Have a setup like so:
Queue 1 > Activity 1 > Activity 2 > Queue 2
Activity 1 will have a cycle time of 5 minutes
Activity 2 will have a cycle time of 60 minutes
Ensure that Activity 1's "Routing Out" is set to passive, as you are linking activities back to back.
Set the Replication value of Activity 2 to 12 (do this by selecting the Activity > Additional Tab of the ribbon > Replication value to 12)
Postby Simul8or » Mon May 22, 2017 8:48 am
Great thx. Works exactly how it was intended :)
Postby Simul8or » Mon May 22, 2017 12:21 pm
ok I have the following concern:
when the cycle time of Activity 1 is 5 minutes, the item is delayed by 5 minutes instead of letting through an item every 5 minutes, right?
That kind of serves the purpose, however every items takes 5 minutes longer than expected.
Or am I missing something?
Thx!
Postby Simul8or » Wed Jun 07, 2017 10:10 am
push
